Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6LLO-6
Fit Landing Light Lens
Added two way tape to the upper backing strip and trimmed out the holes and edges.
Image 2) test fit screws before removing the backing.
Image 3) Top is attached need to make sheet metal screw backing strip fot the bottom. Done for the night.
Trim tape away from holes
Test Fit
Top is Fitted
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
