Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W8-1
LE Top marking and drilling
Removed the LE Skin and placed it on the cutting table to mark and pilot drill the spar cap rivet line and the top nose rib lines.
Image 2) Reset the bottom LE skin by clecoing the spar cap angle first at each end on the outside of the bottom rear skin.
Image 3) Draw the straps up some before clecoing the bottom nose ribs.
Blocked up
Cleco bottom spar cap angle
Draw up the straps some
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
