Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W8aa
Check forms and set front spar height.
Checked the forms for integrity. Looks good.
Image 2) Screwed the plywood skid stops to the Wing Spar Risers.
Image 3) Added 1/4" pads to keep the spacing consistent. Mounted the forward risers the same distance from the table edge. Used 4 of them.
Forms look good
4 forward risers
1/4" spacers (spar caps)
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
