Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W4
Ream to 5/16 wing attach holes
Image 1) Check Dihedral measurements after bolting with four 1/4" bolts. It looks good.
Image 2) Align reamer with vee block, and ream away. Make sure to use lots of lube.
Open the holes up using four reamers starting with 1/4" and going up 1/64 each to finish with 5/16"
Always use four bolts and maybe a clamp to ream the two holes, one upper spar cap and one lower spar cap.
Check measurements
Align reamer with Vee Block
Ready to clean up
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
