Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6K1
Forming tank ends
Annealed the corners to make the shrinking go easier.
Process:
Image 2) Lightly soot with acetelene
Image 3) Burn it off, Slowly heat it up with a neutral flame then quench it in water.
It gets soft like butter. The discoloration is from the soot.
Need to shrink the corners
Soot it up
Heat it off and quench
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
