Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W4
Rivet Center Spar 3 of 4
Image 1) This is the process, position rivet head on lower anvil and compress. Hit top fo arbor press 5 times smartly with rawhide BFH.
Image 2) Here you can see the rubber cushion holding the metals down to the rivet head.
Image 3) Center Spar Assembled.
The riveting machine
cushion clamps parts
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
