Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Hang Ailerons & Paint inside of Garage Door
The Ailerons got hung today. The left one still needs work on the trim tab horn (need material) then it can be riveted to the aileron.
Painted inside of garage door to help with the lighting situation. That should brighten it up a little this winter.
Ailerons hung
Garage door before
Garage door after
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
