Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W1-2
Sizing rivet holes and removing twist from Flap
Drilled to final size on the rivet holes (A5). Had to move the 3/4" plywood blocks whe I flipped the part over. I marked everything so I can use this setup for the other flap.
Finished to size on A5 rivets
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
