Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W5-2
Qualify wing nose ribs
Today I made a 3/4" thick 6061-T6 block to the shape of the wing nose rib. Put the radius on both sides and used it to back the metal edge as I tapped the edge into shape.
The hammer face is polished and all surfaces are wiped clean before tapping.
Finished tips on all 14 ribs.
Qualifying block
Gently tapping out wrinkles.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
