Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Stabilizer End Cap Tool
Need to take off the sharp corners and blend the radii. Using 24 grit 3" pad on a die grinder and a 36 grit 6" DA to rough it in. My home air compressor is not up to running the DA. Taking it in to work and use theirs.
Ready to begin shaping
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
