Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6T6
Elevator Trim Tab
Cut out holes for the servo and control rod for the trim tab using hole saw and 9/16 blair cutter for the corner radius. Tested using 2 way tape for full rang of motion.
Cut out holes
Trim tab test.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
