Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Front Center Baffel
Project line on the inside where I think the baffle might go.
The lower line is the line for the two 10/32 screw holes in the bottom front of the roys bearing.
The next line is 2" up from that.
Cowling is tipped 31 degrees, equi-distant from the air inlets.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
