Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Engine idle test
Today the prop was attached and an Idle test was done. Tach works, Engine idles at 750 rpm smoothly now. One of the EGT probes might be bad.
Set timing at 8 degrees at 750 rpm.
Need more fuel to run full static test.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
