Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Baffel oil cooler
Cut some scrap metal and added nut plates to hold the left outer oil cooler flange.
Added top plate with a return flange to block off the air flow getting around the cooler.
Added flanged hole for the oil line to go through the reinforcement. Used laser light on tripod to transfer hole center from the oil cooler.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
