Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-T-2
Forming Stabilizer Skin step 2
Prop open the MDF so you can lift the edge of the sheet metal. Remove toggle clamps from back stop angle. Carefully lower the MDF and sheetmetal edge so they line up. Use support to hold the sheetmetal/MDF open.
Next
Prop open MDF sheet
Match edges MDF & Sheetmetal
Use support to hold open
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
