Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Recheck and reset everything
Setup everythig over again. Trimmed side skins for the rear spar anchor points.
Upper longerons are bolted to the motor mounts, the gear chanel is set, lower seat back is set.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
