Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Wing Jigs
Got these wing jigs from Chuck Z. Had to modify them to work for my wings. Used the rear rib wing form #1 to set the spacing and angles.
All I had to do was remove the rear spar end, adjust for the 3 degree and remount them. Used .025 shims to make up for the rib material thickness.
Also setup and drilled upper engine mounts.
Main spar end w/shims
rear spar end w/shims
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
