Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Frame box for aileron bellcrank support
Cut L-Angles, joggled one end. Pilot drilled end holes thru skin.
Rivet fan for 40mm spacing off end holes on the skin.
Drilled and clecoed, deburred and riveted bottom frame.
Top frame is riveted to support and clecoed to rib. Need to pisition top skin and mark / drill end holes.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
