Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Left Aileron Upgrades
L-Angles for trim motor support.
Fit everything then removed the aileron balance arm to rivet.
Placed the balance arm back in and torqued the bolts.
Placed the other two joint reinforcement plates, drilled, deburred and riveted aileron closed.
It still has the 13mm washout / twist.
Trim motor reinforcement
Rivet without arm in
Closed up and ready to fit to wing
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
