Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Puttering with wing upgrade
Setup other table and brought in LE skin to make templates to hold the 3 nose ribs in place.
Placed top wing skin and drilled rivet holes in the new spar.
Sealed fuel tank and tested for leaks, found one at the ground wire screw on the float, tightend screw and the leak is gone, glove stays inflated.
Set templates in place, ready to cut nose ribs to fit new setup.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
