Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Removed leading edge and nose ribs
Layed out and drilled for the L-Angles, using every other hole of the rivet fan for 100mm or less spacing. Tape off holes not to be used.
Removed leading edge skin and all the nose ribs, makes it easier to work.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
