Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Remove right wing tip
Drilled all the rivet heads off the outer face, marked wires and cut wires to store wing tip for later.
Only 3 wires to mark all others were on connectors. Might make connectors for those three also.
Mark wires, cut wires
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
