Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
MA3SPA
Remove stuck parts from Carb
Setup carb and trammed in the OD od this boss. Drilled with number drills till I could see the threads.
Looks like 1/4-20 threads for the orfice / check ball.
Float seat was stuck so I made up the 50/50 Acetone/ATF mix, heated, beated and ground down a pry bar to get it free.
What fell out at the end
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
