Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Hook up Air Brush and test
Looks like it might work need to run the pressure between 30 and 50 PSI. Need to test again without thinning at the higher pressure and see how it lays down. To much mist to do in the garage but it might work out OK in the spray booth.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
