-Started to route the firewall forward fuel lines. I need to get the fuel from the firewall port to the red fuel flow transducer then to the mechanical fuel pump and then to the fuel injection servo. -Removed the mechanical fuel pump to removed the cracked and ugly cooling shroud and change out the fittings for the ones Van supplied in the FWF kit.
Fuel pump removed and fittings removed
The fuel pump to fuel servo firesleeved line show roughly in place - not connected to the pump yet
