-Started last session working on the mixture cable. This one was especially problematic given I have a B&C starter so the mixture arm on the bendix throttle body hits the starter when rigged per the plans. I contacted Don Riveria at Airflow Performance and he sold me an arm that is more offset to clear the starter motor - just barely. -I installed the mixture cable and ran it to the quadrant along with the throttle and prop. I had to dissemble the console to get the cables loosely attached to the cockpit cable support bracket - it's tight. I didn't realize I needed special clevis ends so I have to order those this weekend. Everything is loosely fit for not until I get those clevis' I'm pretty happy with the length - thanks VAF, esp Steve! and the routing looks good thus far.
Cables routing into the cockpit and loosely in place on the support bracket
Cables running through firewall. Top is mixture, middle is prop and bottom is throttle
The convoluted mixture control. Note the 'new' black arm on the servo and the BIG starter motor.
