-Installed the appropriate fittings on the fuel pump with fuel lube and reinstalled the pump on to the engine. -Concerned about clearance issues I decided to put the mags back on - just temporarily - they aren't timed. -Put the line that runs to the fuel pressure manifold on -Put the fuel pressure sendor on the manifold -Roughly located the 'red cube' fuel flow sensor. I need to use a 90 fitting to use my existing hoses so we'll see how it goes. The mfg says 5" of straight run before and after the sensor, but almost no one can do that and most folks have mounted it in crazy places and it works fine.
Fuel pump back on and plumbed. I need to firesleeve the fuel press line though.
