Misc stuff: Located and drilled transponder antenna hole. I located it under the passenger floorboard on the right hand side. Tried my hand at crimping molex pins. I installed the strobe cable that runs from the power supply to the wing roots where I will have another connector for wing removal. It was fun after I figured out the how the crimper worked, etc. Thank goodness for the internet! I routed the strobe wires the the grommets in the various bulkheads and located and drilled a hole through the side of the fuselage at the wing root where it can exit. I also riveted the nutplates onto the comm antenna doubler. I'll have Mitchel help me rivet it in place on the fuselage this weekend.
Xponder antenna installed
Here's the right hand strobe wire awaiting a 3 pin molex connect (which I need more of)
