Brent s RV-8 Project N784DE
Date:  8-17-2010
Number of Hours:  1.80
Brief Description:  Cabin Heat Mixer #1
-I had previously located where the cabin heat mixer box would go on the firewall, but now it's time to figure out how to actuate it with the cable.
-I drilled a #19 hole in the firewall for the cable to exit with plans to use a ss cable grommet/cover.
-I then routed the cable roughly in position to locate the holes in the gear tower and drilled them to size
-I then put the cable through the holes and decided I need to fabricate a bracket out on the firewall to keep the cable in the proper position - I upgraded to the ss mixer box and of course it's different than stock which is decidedly easier to install.
Cabin heat selector/mixer box
Black know next to the parking brake T-handle is the cabin heat selector
Here's where I need a bracket to anchor and support the cable
