-Once I tried to route the prop cable it was clear that I didn't orient the cable bracket on the governor properly - I was alittle unsure about it when I installed it. -Off comes the governor and it took 2 hrs to remove the bracket and cable and actuator arm and reinstall and re-safety wire.
