Brent s RV-8 Project N784DE
Date:  8-22-2010
Number of Hours:  2.50
Brief Description:  Sealing firewall components and bulkhead riveting
Kind of random today. I put flamemaster sealant on the upper firewall penetration (EMS wiring) and resealed the naca scoop in place
-Trimmed and attached the smoke oil line
-Mounted the cabin heat box permenantly
-Started riveting the fwd baggage compartment aft bulkhead top and bottom together - not sure why I left that unriveted, probably to mount hangars for wire runs, etc. Then my air compressor quiet. I think it is the start capacitor. I need to order one so I'll work on non-pnuematic stuff in the interim.
Riveting the fwd baggage compartment rear bulkhead - compressor quiet before I was done
Sealed the upper firewall penetration
Second attempt to attach the naca with sealant - next time I'lll rivet if this fails
