-Final fitting of the right wing tip lens -Drilled the tip and lens for #40 and cleco'd and re-checked fitment -Drilled to #6 screw (lens and tip) -Drilled the tip for #6 nutplates -Drilled access hole in the center of the recessed
Nutplates drilled top and bottom - I have no idea how I'm going to set those rivets
Still trying to figure out the best and most astestic way to handle this
