Brief Description: Empennage fairing #10 and Upper Gear fairing #20
-Sanded the micro that I added previously and removed the fairing from the empennage. I then put some micro on the lower part of the fairing that runs under the HS.
-I wet sanded the primer filler, added 2 more coats and wet sanded again. I then shot it with black primer (for the chrome) and wet sanded most of it away. Applied two more full coats of black. I plan to lightly sand this coat and then go with the dupli-color chrome.
After wet-sanding the second primer filler coat
Here they are after the last coat of black primer
Here is the underside of the fairing with a coat of micro
