Brief Description: Empennage fairing #9 and Upper Gear fairing #19
I continue to work on the empennage and gear fairings each sesssion.
-Wet sanded the previously filler primed gear fairings with 400 grit and clean off. Next session I'll put another coat of filler primer on.
-Did some additional sanding to refine the emp fairing and then layed some micro on the low spots. It's coming along pretty good. I need to sand it once it dries and evaluation if I need more micro or I can start skim coating it.
The filler primer is gone on the high spots and hopefully i'll help fill the scratches
Here you can see I sanded away alot of micro to work it smooth.
