Brent s RV-8 Project N784DE
Date:  6-25-2010
Number of Hours:  1.00
Brief Description:  Empennage fairing #8 and Upper Gear fairing #18
-Shot a coat of filler/primer on the intersection fairing. With that on there I could see the big scratches left over from the 36 and 80 grit paper - I sanded it with 150 and 400, but evidently not enough. So more sanding for those buggers.
-I then took the 36 and 80 grit to the emp fairing and I have hit worked down pretty good. I will work it alittle more and then add more micro to my low spots next session.
Upper landing gear intersection fairings in primer
It doesn't look it, but it's much smoother than when I started :45 minutes earlier!
