-Did more trimming of the upper gear intersection fairings -located and drilled the attachment holes in the rear of the fairing - upper and lower -Mixed up a slurry of flox to fix some of the problems at the trailing edge of the fairings - I had left the rear upper and lower surfaces unattached for removal, but I decided to bond that seam and make a new one underneath like the fairngs, etc folks do. I think this will look better -Mixed up some dry mico and frosted the fairings (1st iteration of the fill and sand, repeat 100 times ritual)
Trimmed to my likeing. These are shaped to go around the wing root
