Brent s RV-8 Project N784DE
Date:  7-5-2008
Number of Hours:  4.20
Manual Reference:  8-24
Brief Description:  Adding Tailcone to FWD Fuselage #1
Out into the garage by 6am looking to have another productive day.
I knew today would be fun as the 'visual progress' would be very high!
-Started out riveted the F810 bulkhead and the F810C angle together.
-Riveted the seat belt bracket together per the plans.
-Final drilled #30 the F807 bulkhead to the aft left/right arm rests.
-Uncleco'd the right side of F807 in preparation for adding F824R aft side skin.
-Cleco'd the Right and left side skins into place
-Cleco'd F808 bulkhead to the F824 side skins and baggage ribs.
-Cleco'd F809 and F810 into the fuselage
-Final drilled the F808 to the F818 baggage ribs.
-Cleco'd F828 aft bottom skin section and F811 and F812 bulkheads together (kindda tricky)
-Uncleco'd the aft portion of the bottom skins in the mid-fuselage to allow the F842 aft bottom skin to slide underneath.
-Attempted to cleco the F842 tailcone bottom skin into place. Not having any luck lining up the holes. Then I realized I had the F824 side skins OUTSIDE of the mid fuselage skins and they should have been inside-not good. The whole assembly had to be uncleco'd to get then under (I tried just removing part of the assemby but the alignment got very wierd so I just started over. Lost about an hour on that screwup - oh well!
-After getting everything back to the right spot Icleco'd the F842 tailcone bottom skin to the aft side skins and the longerons and the mid fuselage side skins. I still need to cleco it to the bulkheads but I ran out of time and clecos - again! Avery gives you about 200 less than you need of 3/32" and 100 too few 1/8"
I have to say it looks VERY COOL!!! Too bad I'll have to take it all apart before it rivets togther- such is the life of a metal airplane constructor.
Top is riveting the F810s and bottom is the seat belt brackets.
Top pic shows right aft side panel going on. 2. Shows the left one. 3. Bulkhead being installed.
1) Bulkheads in. 2) bottom skin going on. 3)Cleco'ing the bottom skin on - note the glove-blisters!
