Brent s RV-8 Project N784DE
Date:  2-9-2011
Number of Hours:  1.70
Brief Description:  Smoke Oil Filler Access Cover #2
Out of town for work supporting Super Bowl flight ops in Dallas so I lost some building time.
-Started cutting out the cover for the smoke oil access. Not sure if I'll use the one I cut or do another one - we'll see.
-Cut out the doubler.
Used the fly cutter on the drill press so there was a little learning curve and some waster material, but I believe the doubler is good.
-Located the holes in the fuselage for the doubler rivets
-Clamped the doubler in place in preparation for match-drilling.
The fly cutter, aka man-killer, does a nice job, but one must use caution!
Removed the blue film and drilled the rivet holes for the doubler
Doubler clamped into place.
