-Match drilled the doubler to the fuselage rivet holes in the skin -Made another cover plate as my original was slightly small -Located and drilled the fastern holes. I'm using 1/4 turn (4) fasterners for the cover -Drilled the camloc receiver rivet holes.
After final analysis I think I'm going to redo the doubler and cover as they doubler doesn't extend far enough into the hole to give me good spacing on the holes that are drilled in the cover. It should take long as I'm starting to get good at this ;)
