-Back to the ole' fwd baggage door. Since I modified it extensively for my windshield extension, I'm slightly off the plans. I'm needing some misc parts for the FWF; oil fittings, hose, firesleeve, new cabin heat muff, rpm sensor, etc., so I'm working on something else for a bit which is a much needed break.
-First order of business was to put the cowl on so the firewall skin was in the final position -Located all the door parts - not easy in my shop after a 1 1/2 of not touching the door. The previous entry for the fwd bagg door was July '09. -Then I riveted some fo the substructure on the door that I had cleco'd -Cleco'd the inner skin on. -Put the hinge and pin in temporary and set it on the fuselage. Fitmen looks pretty good, but I have some trimming and tweaking to do.
