-Sanded the previously applied resin and peeled away all the tape. The edge looks pretty good. It's alittle crusty but that will cleaned up with slight and careful sanding along the plexi and painting up onto the plexi approx 1/16". I still need to make sure the inside looks ok now that the tape is gone and I need to make sure the canopy skirt transition doesn't need more work. I am mostly concerned with the edge between the plexi and the fairing. 26.3 hours on the installation alone - doesn't count cutting the windshield out and shaping it back when the canopy was done.
