Brief Description: Fitting wing skins - left wing upper
Up a little late this morning (545) and worked for almost an hour on fitting the wing skins. You cleco the skins on (top and bottom) along with the wing walk doubler and match drill to the skeleton. I had to tweak the jig so the out board skin would fit. It hanges over the edge about a 3/8". I cut a small slit into the support are and luckily the threaded rod didn't interfer.
Cleco'ing the wing skins
Coming along
Slit I cut into the support to alow for the skin overhang.
