Brent s RV-8 Project N784DE
Date:  12-17-2006
Number of Hours:  1.20
Manual Reference:  6-11
Brief Description:  Riveting Left Elevator
Got up late so I only got a small amount of time to work on the plane, but I did manage to get the elevator skin riveting almost done and I blind riveted the false spar were the trim tab mounts per the plans. It calls for MK319BS blind rivets so you need to drill the hole out from the #40, that you drilled previously, to a 7/64 or #33. This worked well and the flush blind rivets don't look bad at all - I was supprised. Hopefully, I can finish up the skin rivets today or tomorrow and then I will turn my attention to the trim tab itself.
Squeezing rivets to attach the skin to the under-structure.
Blind riveting the false spar for the trim tab in the last 4 holes per the plans.
The bottom skin is completely riveted.
