Brief Description: Left Elevator Riveting/Trim Tab fitting
Rick Blaes came over this morning. He finished up riveting the bottom skin and I worked on the trim tab. When it came time to bend the ends closed on the trim tab it was a team operations, came out pretty good, but I may elect to build another one at a later date. Many folks cut the tabs off and elect to fabricate thier own little rib to close up the ends of the trim tab. Rick match drilled the trim tab spar and hinge. Good progress though!
Rick finished up riveting the top of the left elevator
