Brief Description: Elevator / Horizontal Stab Tips #3
-The reinforcement strips on the elevator causes some problems because you can't hold them in place when you cleco the tips into place. Since I didn't have any 5 min epoxy I used the epoxy that is normally reserved for the normal glass work. I painted some epoxy onto the strip between the rivet holes so the cleco's wouldn't be glued in. -Next I finished riveting the nutplates onto the HS strips (the most forward ones I couldn't get to with my squeezer, so my buddy Greg is bringing our shared yokes set to work so I can use the thin-hole yoke to get into that tight space).
Strips 'glued' into place on the elevator tips.
HS tip - note the cleco where I need the thin nose yoke.
