-Used a piece of welding wire to make a pattern of the brake lines that are inside the gear towers. -Transfered that piece to the 1/4" aluminum line (x2) Turned out pretty good. I need some tubing to wrap the lines in so they can't chaf against all those screws that I have with my removable cover (web). I'll pick that up today when I'm out running errands.
Brake lines for inside the left and right gear tower.
