-Installed the left wheel pant -Put an additional screw in the right upper intersection fairing to close the gap it had with the fuse in the front. Left one fit better all the way around. This will be a redo item...add it to the list. -Spent too much time trying to figure out my elevator trim wires. Finally found were I wrote it down in the wiring book. -Temporarily installed the etrim and tested. Works good, but the EFIS trim indicator moves backwards - fix it later... -Installed the empenage fairing and rearward fuselage inspection covers -Safetied the elevator trim tab hinge pin -Installed the rear five point harness -Installed the rear side covers -Installed the front and rear seat backs -Tried to connect the rudder cables and couldn't get full throw. :10 on VAF I found the answer, master cylinder needs to be relieved slightly to allow pedals to move forward. Some of this stuff will come back off after the weight and balance is done.
