Again lots of little stuff. I didn't have enough panhead screws to secure the interior so I skipped around alittle. -Installed the gear tower covers. Put a robber liner on the right one to protect wires - see pic 2. -Installed but only put a couple of screws into the rear bagg compartment parts (3). -Insatlled with only a couple of screws the fwd seat ramp pieces and rear rudder guides. -Made spacers for the Crow seat belts (2). -Installed the wing root fairings with cleco's. I lost the gasket somehow so that is on order. Need that before I can screw them down -Torqued and safetied the brake caliper bolts -Cotter pinned the wheel nuts -Aired up the tires to 49 psi -Installed the upper intersection fairing. I need to put a screw in the front to pull it up tight, especially on the right side. Didn't have the ss screws on hand for this either. -Installed the right wheel pant. Started on the left one before I had to get home.
