Brent s RV-8 Project N784DE
Date:  3-17-2010
Number of Hours:  3.50
Brief Description:  Relay fun #1
It was time to wire up the 3 relays I have, or will have, mounted on the bulkhead that separates the cockpit from the fwd baggage area. One is for the flaps (Advanced Flight Systems relays board) the other one is a simple spst from Radio shack for the smoke pump and the other is another radio shack dpdt for the e-trim.
After spending more than a half hour trying to figure out how the two relays from radio shack worked I was in business.
Got most of the smoke relay and most of the e trim one wired up and the wires all labeled.
Wiring the elevator trim relay
Smoke relay snuggled between the bridge rectifier and the flap relay board.
As a side project I've been playing with some simple labels - this is my 1st try, but i plan to redo
