Brent s RV-8 Project N784DE
Date:  3-18-2010
Number of Hours:  4.10
Brief Description:  Relay fun #2
More wiring of the relays and stuff.
-Crimped on all the connectors for the smoke relay, e trim relay, flap relay, and bridge rectifier for the ebus. Also I ran the flap motor wires. All this stuff resides just fwd of the right gear tower on the bulkhead that separates the baggage compartment from the cockpit.
-I then fabricated a bracket to hold the e trim relay (radio shack dpdt). Turned out pretty nice. I drilled the holes and installed with #8 screws
-Then I connected all of the wires.
As an aside I clear coated my instrument panel with the switch labels (I'll do the other labels at a later date). Turned out ok, but I used a satin clear and it turned out glossy'er than I wanted, but it does look passable. What I really want is my friend Mike to anodize it black - not sure he can does something that big.
I started organizing the shop yesterday and I have the floor plan all set, but now it's time to organize the shelfs, etc.
e trim relay bracket with base installed and wired.
All this stuff lives behind and under the instrument panel.
